How to replace ignition coil
I want to replace the ignition rotor. I took off the distributor cap and a pulled on the rotor. It didn't result in it coming out. I used to replace them on old American cars and they just pulled off. I just want to check before I put more force on it to remove it.
This may help others. By leaving the cap off and advancing the engine slowly with the ignition key I found a Philips head screw holding the rotor in place.
