Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
How to replace ignition coil?
Old 03-14-2013, 08:22 AM
janek's Avatar
Default How to replace ignition coil?
I want to replace the ignition rotor. I took off the distributor cap and a pulled on the rotor. It didn't result in it coming out. I used to replace them on old American cars and they just pulled off. I just want to check before I put more force on it to remove it.
This may help others. By leaving the cap off and advancing the engine slowly with the ignition key I found a Philips head screw holding the rotor in place.
Old 03-14-2013, 02:14 PM
Mr. Dabolina's Avatar
Default Re: How to replace ignition coil?
What year and car is it? No Accord 03+ should have a distributor as far as Im aware.
Old 03-14-2013, 06:06 PM
BLKFLSH's Avatar
There is probably an allen set-screw holding it to the shaft. This is obviously not an 03+ Accord.
Old 03-14-2013, 06:09 PM
Fliptard's Avatar
take that phillps screw out and it should pull right off, somtimes the screws can be a #$%^#$ to get off, and the rotors get stuck too, just don't break it. Than just pull the black cover off and you'll see the coil. @ screws with wires, and 2 holding it in. and your good
DredwerkZ
04-19-2004 05:21 AM
Utilitarian
07-14-2003 04:53 AM
b18tdelsol
05-04-2002 10:18 PM
bocian
02-20-2002 06:50 PM
Quick Reply: How to replace ignition coil?
