gsr build
hey i recently purchased a 94 hatch with 2001 gsr with b16 trans an di have decided to boost it.
so far i have purchased a nsr t3 flange dual wastegate topmount mani
a freshly rebuilt holset h1c
38 mm tial wastegate (still need to upgrade the spring its currently at 8.70)
arp head studs
arp main studs
and a comp clutch stage 4 six puck
the block is currently at the machine shop getting
a hone and the deck checked out, the crank is also being inspected once i i know what size bearing i need i will order the bearings some rods an low comp pistions i will post some pics of m build as it continues my goal is around 375-400hp
arp head studs
arp main studs
"In that case" So you think that .2 liters in displacement makes it much easier to get to 400whp?
Haven't been around honda's much I take it...
thanks for all the compiments on the car im plaing on having it repainted the same colors it is chipping in some spots, im also going to to sand down the bay and paint with por 15. I wasnt planing on doing anything with oil cooling. but on the other hand i talked to the machine shop today and my crank has to be sent out to get turned, and the #1 cylinder is a little bit tapered 0.015. the other cylinders were pretty close to stock spec's. so they are going to bore it out .20 really makes me wish i would have gone with my first route and had sleeves installed oh well. hopefully i will start puttin this motor back together once i get back from japan
Well got a bunch more parts I've now ordered up my acl bearings and cp pistons 9:1 and a set of eagle rods and bought a set of blox valve springs and titanium retainers of Craig's list. My crank needed to be turned so my block and crank should be ready soon. If anyone has some blox cams for sale pm me. I went with the dual 38's for baller status and if I wanna change my setup down the road for a more streetable car
