12.2 comp c1 dd? or 11.1 dd
Just looking for some opinions. I have a 95 b18C1 I'm rebuilding and have new usdm itr pistons on oem rods. I currently have 98 itr cams. I also have a set of eagle rods collecting dust and was considering supertech 12.2 comp pistons.(they will allow me to keep aclose p2w) Will 12.2 be to high for pump gas? Will the oem cams work well with a Higher comp or would I be wasting my money .
You'll be ok with the 12.1 on a DD Chicago isn't to high. You could get Skunk2 tuner 3's maybe pro 1's ?(you'll need to degree the pro 1's 100%) wouldn't hurt to do the same on the tuner 3's should you run those. assuming you've got all basic bolt ons you'll hit you'r mark
bit the bullet and got the supertechs, they are actually 11.9:1 on c1 heads. I'm sticking with the itr cams for now. this entire build has been from lurking on ebay for months waiting for deals. ill get cams when the time comes lol. anybody know what p2w I should run? they advertise .0038 heard they slap at that setting
Posted from Honda-tech.com App for Android
you can go higher than that once you get big cams. I ran 13.0 daily for a year. 7k miles on e85. I have a fill station 2 miles from my house. I bet you live next to one of these stations
http://www.e85locator.net/State%20Pa...s.html#Chicago
im running 12:5.1 in a c1 with tuner 2 on 93 it made 193 whp wit ha stock gsr throttle body and hack welded dnr header i have since changed to a 68mm throttle body and toda rep header and longer 3 inch intake tubing hoping to hit 200 whp mark
is there anybody making 200 whp on the stock cams? or are they the choke point on most builds? i have good supporting mods. this is just a side project with parts that i have lying around so i would hate to shell out 500$ just for 10 whp.
I think you would be hard pressed to find a build like this making 200whp with stock cams. I am not saying it is impossible, but it is very unlikely and I have yet to see one.
ITR cams should respond to higher compression, but the question is how much. Just make sure you get a good tune and you should see fairly decent numbers and reliability.
im planning a similar build, about 12:1 and i want to use itr cams for that very reason. i know they will respond well to a lower vtec somewhere in the mid 4000 rpms, giving a nice wide powerband
There are a few other 200whp with ITR cams that I can think of.
No AC and PS with 12:1 comp. Has made it.
Another one I know of had the transmission redone, lower friction bearings and NO AC and PS made it.
not really sure what ur asking I'm sure about? if I can run the motor on 93? because that was one of my original questions lol. anyone know if the s2 springs will work on a rsx chromoly retainer? I tried the b series retainer today and the inner spring has to much slop. its a larger diameter than the oem b series
Remove my powersteering belt and I'm there with ease. **** if my brakes weren't so heavy or my wheel/tire setup for that matter I'm sure with PS I'd be higher than 200WHP. If I can do it with 11.1:1 you can definitely do it with 12:1. Stock cams seem to choke out carrying torque more than anything though, and you can get away with higher static compression ratio with bigger cams to change the dynamic compression ratio.
Keep stock, your head will flow better,
and the BRZ pretty sure has direct injection (along with port so well both) that is how it can have 12.5-1 and run on 91 pump gas, the design on these motors are over 20 years old, the BRZ has a modern engine so things are kinda of different.
direct injection makes a difference. im sure they run an uber-active knock sensor as well.
i "think" the rsx retainers dont need to be as tight as a ti retainer because they will not wear down in the same fashion? what i do know is that there are a fair amount of people using the rsx retainers a the moment with respectable rev limits with no adverse effects. i even picked up a set for myself
I'm not running ti. I see no reason at the moment. I am hoping the retainers fit and skunk didn't make there own profile so that u would be forced to use their retainers
I Have an STD
12
Dec 7, 2003 02:21 AM
