91 crx rev but will not stay running
Old Mar 11, 2013 | 11:26 PM
fitbkeco's Avatar
Default 91 crx rev but will not stay running
So I recently did a head job on my 91 si and now when I try to start it, it won't run just rev and die... When I spray starting fluid into it, it will stay running I have no idea what the problem is
Old Mar 12, 2013 | 04:00 PM
fitbkeco's Avatar
Default Re: 91 crx rev but will not stay running
Bump
Old Mar 12, 2013 | 06:45 PM
fitbkeco's Avatar
So I've gone over everything I did again the car is on time and its getting fuel and spark. It wants to start but something is holding it back
Old Mar 12, 2013 | 08:55 PM
blk91crx22's Avatar
You could check compression or see if there is a restriction on your fuel return line for a start
Old Mar 12, 2013 | 09:16 PM
fitbkeco's Avatar
i check compression and its good in all the cyclinders i read somewhere that it coould be the ignition switch but would it run off starting fluid if that was bad
Old Mar 12, 2013 | 09:47 PM
blk91crx22's Avatar
Yeah it still would run off of that which means it might not be getting fuel back into itself
Old Mar 12, 2013 | 10:39 PM
fitbkeco's Avatar
How would I check for that
Old Mar 13, 2013 | 07:20 PM
fitbkeco's Avatar
Bump
TehTaylor
26
Jan 30, 2012 11:49 AM
Schayward420
Oct 25, 2009 06:19 PM
dvlsfan30
Apr 21, 2009 01:17 PM
slowslow
11
Apr 29, 2008 11:34 PM
mathew206
Nov 15, 2006 01:11 PM
