Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Cracking, grinding noise when turning left
Old Mar 11, 2013 | 08:52 PM
element7's Avatar
Icon6 Cracking, grinding noise when turning left
Hi guys!
My sister has 07 Civic and she told me that when she turns left there is cracking and grinding noise coming from somewhere under the hood. During last oil change at honda dealer they said that apparently her right axle boot was open/dry and needed replacement. Quoted her about $410 for the job.
I was wondering if she just keeps driving with same supposedly broken part -
1. will it completely fail someday soon and possibly get her into accident or something?
2. Is it safe to drive at all with broken axle shaft?
3. How hard is it to change this part? I wonder if taking to non dealer for cheaper labor is good idea or is it best for dealer to do this?
Here's the part # they said need to be replaced: 44305-SNE-A01
Old Mar 12, 2013 | 06:18 AM
97emsedan's Avatar
Default Re: Cracking, grinding noise when turning left
Originally Posted by element7
Hi guys!
The answers to these questions are:
1) Yes, and spectacularly I might add.
2) No, the axle shaft is the means of transferring power to the wheels to move the car, with a broken shaft you are doing damage to the critical driveline components that the shaft interacts with.
3) without the proper tools and training, you will damage more parts trying to remove the hub and brake assemblies and possibly bend your control arm when separating the ball joints to get the shaft clear of the hub. Take it to a certified garage or a dealer mechanic and have it done right. A wheel alignment is usually required after suspension components have been removed or adjusted. Use the OE parts listed in that number to maintain reliability.
Jochem17
Dec 22, 2018 01:28 PM
Apple395
May 28, 2015 10:09 AM
ChrisTechMech
Suspension & Brakes
Jul 7, 2014 05:48 PM
lopezchris21
14
Aug 10, 2008 06:57 PM
Hykos
Honda Civic (2001 - 2005)
Sep 7, 2007 04:59 PM
