Could use some help fella's.
Old Mar 10, 2013 | 04:54 PM
hondaproof's Avatar
Default Could use some help fella's.
My 91 sedan d15 shut down on me a few days ago. After replacing the cap, rotor, ignition module, coil and checked all fuses, grounds, battery, belt... about everything. It's cranking and everything is in order, including fuel, and I'm getting nothing. Anyone got any suggestions?
Old Mar 10, 2013 | 04:59 PM
Spug's Avatar
Default Re: Could use some help fella's.
Timing. Check it.
Old Mar 14, 2013 | 03:03 PM
hondaproof's Avatar
its in time, unless i did it wrong. still cranking and nothing. ive got new steering wheel,coilovers and camber kit im itchin to put on it.
Old Mar 14, 2013 | 03:36 PM
smokey2.0's Avatar
Got spark? Pull out a spark plug and attach it to one of the spark plug wires. have someone crank the engine, while you check for a spark crossing the spark plug gap.
Got fuel? disconnect the return line from the fuel rail, and see if fuel comes out when you crank the car? Good luck.
Old Mar 15, 2013 | 05:56 AM
zrickety's Avatar
Are you saying you replaced the timing belt? Was it broken? Check the firing order of the plug wires and your grounds.
Old Mar 15, 2013 | 08:17 AM
festivagt's Avatar
If there is no spark it's usually best to change the distributor as a whole. (its faster and replaces a slew of things to replace individually)
Old Mar 15, 2013 | 12:49 PM
hondaproof's Avatar
The belt was not broke, it looked good.it is getting spark and fuel.ive never timed a d series however.i took notes on the process, I may have it wrong.ecu? maybe?
Old Mar 15, 2013 | 01:09 PM
grog's Avatar
Are there any CEL codes?
Can you get it started by push starting it?
Is you fuel level low? I ask becuase some peoples EF's act like they are out of gas at a 1/4 tank, caused by a torn or bad fuel sock.
A compression test would be helpfull along with double checking your timing.
Old Mar 15, 2013 | 01:40 PM
hondaproof's Avatar
No codes. I haven't tried push starting it. Tank is full. I can't test the compression until Monday. I did a search on checking/putting it in time,most everything I found wasn't really helpful.
sleet_22
Dec 9, 2013 02:09 PM
dskater411
Mar 28, 2008 09:36 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
QTKEG6
Jun 23, 2002 10:14 PM
