TPS vs MAP
Old Mar 10, 2013 | 04:06 PM
10cjennings's Avatar
Default TPS vs MAP
How do you differentiate between the two engine harness plugs? I've searched and surprisingly found nothing considering this is such a common mistake.
I replaced my k20a2 engine harness and the car wouldn't start, unplugged both TPS and MAP and it barely ran, switched them and it starts but idles really high and keeps rising.
Old Mar 12, 2013 | 06:25 PM
turbohatchBnuts's Avatar
Default Re: TPS vs MAP
I can tell the difference by the lenght of the harness.Their is an arm in the harness with your Map plug , Air temp plug , and your gas vap purge plug all on the same arm. Then right were that arm comes out of the harness theres another plug, should be shorter. Thats your Tps plug. If that still doesn't help, check your grounds. Do you have Kpro?
Old Mar 12, 2013 | 06:29 PM
It's not that easy. I thought I had it right because of the length of the harness but I just had it routed a different way. The best way to tell is that the TPS is the one whose middle wire is red.
Old Mar 12, 2013 | 06:37 PM
I have already had the same problem. You can check the color code of the wires , length of the wires , or just know which ones they are from doing so much work on k series. I edited my first post to help you find it better.
Old Mar 12, 2013 | 06:56 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I've made this mistake before it's easy and stupid... but I did it on my GSR... The sad thing is they keep making those two plugs next to each other identical... wtf
Old Mar 12, 2013 | 08:01 PM
It Wasn't Me's Avatar
Label before disconnecting.
No problem later.
B_Swapped93
May 2, 2017 09:35 AM
ls/si newbie
Apr 23, 2016 01:46 PM
rsw912
Jul 11, 2012 03:06 PM
AdamB18C1EK
Feb 26, 2007 05:57 PM
RudeLude95
Apr 14, 2005 11:30 AM
