suddenly running bad.
Hey guys so my 95 has suddenly started running really badly. Im thinking its the cold because it ran fine when it wasnt all cold and snowy. Anyone have any thoughts on how to make it run normal in cold *** weather?
Can some define "running badly"? There's absolutely no information here to work off of.
Are you throwing and CELs? Gas mileage bad? Idle issues? What?
what it sounds like to me, is your filter was clogged before you changed it causing your fuel pressure to be lower... ok so now you changed your filter allowing your fuel pressure to come back up where its supposed to be but now your running rich/flooding the car..... to me it sounds like either your fuel pressure regulator is bad or your injectors are bad... the reason you didnt know that before was because the clogged filter lowered the pressure enough for the car to run right!! im not saying its for sure 100 percent your problem but ive seen it before and might give you a place to start looking!
I pulled the plug boots out 3 days ago just to see if they are intact and the were wet with some sort of liquid but i did spray a plug cleaner in there like the day i bought it.
well if the plug boots are wet its usually oil coming from the seals that are supposed to keep the oil from getting into the plug area!! but in order to see wether its rich or not you have to actually remove the plugs from the head and look at the end that goes into the engine
Mileage on the car/motor? Also you didn't answer marks question, does the car have a CEL(check engine light)?
Inspect the spark plugs, wires, distributor cap/rotor, and coil. Replace if necessary and move from there.
aphex23
13
May 21, 2004 05:24 AM
slowd16z6
14
Apr 11, 2004 05:05 PM
