front left caliper problem
Old Mar 7, 2013 | 11:24 PM
ameer_vtec99's Avatar
Default front left caliper problem
hello H-T
few days back i noticed that my front left wheel is stuck so i remove it and open the caliper and bought a caliper kit .so i changed the seal and test the cylinder wheel if its returns after pushing the pedal and it works fine so i fit it again and i drive the car for a test every thing was fine but yesterday same problem .
my question is any other part will cause this problem like the MC or brake lines or the brake fluid distributor ?
note i bleed the fluid several times . HELLLP PLS
Old Mar 8, 2013 | 01:06 AM
Default Re: front left caliper problem 99 civic vti
Originally Posted by ameer_vtec99
hello H-T
Old Mar 8, 2013 | 05:45 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
The caliper piston isn't retracting?
Are you sure you cleaned the seal grove thoroughly and reinstalled the seal properly?
Old Mar 9, 2013 | 12:20 AM
yes i clean it very well .
that's correct the piston isn't retracting .one more problem happened also there is no pressure in the brake booster
LXcivic2000
Mar 27, 2017 07:41 AM
MurtazaDSM
Oct 19, 2012 09:21 AM
rexracerboy
Aug 15, 2007 09:01 PM
ITR184
Aug 2, 2007 01:05 PM
superhatchbackbros
Jun 7, 2007 09:58 PM
