Really low idle
Old Mar 6, 2013 | 06:36 PM
mitchh29's Avatar
Default Really low idle
My car has an extremely low idle and its been driving me nuts. Ive tweaked the idle cable multiple times ans it always goes back to the low idle. Family members of the previous owner( who is dead) keep telling me he designed it to have a low idle but i just dont believe that. Why would you want that? Its so low it almost dies on me. Fluctuates between 0 and 3 to 5 hundred rps. Any ideas on what could fix it?
Old Mar 6, 2013 | 07:06 PM
crazyhouse2011's Avatar
Default Re: Really low idle
Son, what year make and model is your car?
Old Mar 6, 2013 | 07:14 PM
B_Swapped93's Avatar
Have you adjusted the idle screw idle should NOT be controlled by the TC.
Old Mar 6, 2013 | 07:18 PM
mitchh29's Avatar
Thats what i ment by idle cable. Its a 95 civic coupe. B16a engine.
Old Mar 6, 2013 | 07:21 PM
GnrlKll's Avatar
Agreed. adjust the idle screw. Idle should be 450 at temp with no load if i'm not mistaken.
"There is a process to adjusting the idle...it's not just a turn of a screw kind of thing.
You have to jump the service connector
Uplug the IACV
Now you can turn the screw
Plug everything back in
Reset the ecu"
^got that info from googling.
Old Mar 6, 2013 | 07:29 PM
No its simpler than that. mess with the idle srew then calibrate the TPS that list didn't even mention the most important thing. Op idle should be 750rpm +/- 50
Old Mar 6, 2013 | 07:34 PM
mitchh29's Avatar
O.o i unfortunately know nothing about ecu or whatever TPS is. Im new to this guys, laymens terms please haha
Old Mar 6, 2013 | 07:41 PM
ok here is a pic of the one on my old intake mani. It's the farthest right circle NOT to be confused with the MAP. ignore the left circle is the IACV
Old Mar 6, 2013 | 07:46 PM
mitchh29's Avatar
Far right circle is the TPS? What is the calibration process?
Old Mar 6, 2013 | 07:58 PM
yes that's the tps here is how you calibrate it:http://forums.g2ic.com/showthread.ph...8C-*Sir-G-spec)
Old Mar 6, 2013 | 08:18 PM
mitchh29's Avatar
Awesome thanks buddy
odoscar25
Aug 7, 2012 01:42 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
minner
Oct 8, 2006 01:30 PM
350z-tech
Nov 10, 2001 10:46 PM
