Need DETAILS on a Mitsubishi voltage regulator swap
My 90 Civic LX has a Mitsubishi AHGA03 alternator with a regulator that outputs 19 volts. I do NOT want any half-assed rebuilt from Autozone. Here is the replacement piece.
What is involved in putting that in? Near as I can tell from Youtube vids, a Mitsubishi does NOT open from the rear and the entire drum/stator assy. needs to be taken apart, correct? The brushes are already replaced on the unit so what I want to know is what other soldering would be involved in this swap? Reason I'm asking is I am trying to determine if the swap can be done right inside the engine compartment. I can't get the damn thing out of the friggin' car.
So... your experience doing this job would be appreciated, thank you.
once the alternator is out, all you need to do is open this mother up and tap out its insides using a BFH. it's quite a tedious job but nothing too hard if you're handy with a spanner.
take care of the brushes and good luck
That's no help since I'm crippled and not jacking anything nor getting under anything. Research shows a consensus of moving the master cylinder out of the way after removal of [2] 12mm mounting nuts, allowing lift out of complete alternator. So it's that way or no way.
You still have to get under the car to get at the through bolt, and they can be extremely miserable. In Texas it shouldn't be so bad. Up here with the snow and road salt normally those mitsubishi alternators come out in pieces.
The last shitsubishi alternator I removed:
I have hit the bolt before and they just fall apart like that without beating on the case though. I've also had the cast iron bracket break a couple of times where the through bolt goes through the ears as well. Steel has a nasty tendency to seize in aluminum. Salt makes the aluminum more or less turn to powder. All in all it sucks, half the time you don't get your core charge back.
TITLE OF THREAD: Need DETAILS on a Mitsubishi voltage regulator swap
I specifically asked for DETAILS on REGULATOR SWAP, not ALTERNATOR REMOVAL. If you have NOT done one... I know everyone on the planet seeks attention BUT you really should not be wasting my time... wash your hands, go to church or a bar and pick up a GIRL.
As for the photos above, I wouldn't let you fix me a sandwich. There's no excuse for that kind of damage and you really have NO clue what you're doing.
1/2" Craftsman on the nut with a breaker bar extension from ABOVE the engine, hood open. Crippled besides, you don't know what you're doing, besides crack.
I don't think I've ever seen such a miserable, ungrateful dick in my life.
**** OFF, you did NOT read the TITLE of the thread... did you?
ADMIT IT, you've NEVER done a REGULATOR SWAP, have you? TELL THE TRUTH!
AGAIN.... shut the hell up, I did it myself.
DETAILS OF REGULATOR SWAP
If you didn't know how to do one, you should have just MOVED ON. It has NOTHING to do with "ungrateful". Suppose you asked for a banana and I gave you a lemon?
Actually, I do since I've lived on a boat for 4 years and the zincs need replacement every 6 months. I did NOT ask about road salt though, did I?
So did the TITLE OF THE THREAD! What the HELL is wrong with you people?
You did finish HIGH SCHOOL, right? Because here in Texas, most don't.
Suspect that's the issue, ignorance and an unwillingness to admit you're wrong.
Later guys...
By far you have GOT to have the absolute worst attitude of anyone that has ever posted on this forum. Bar none. Let's see how much help you get after you showed your *** like a baboon at the zoo.
I have a 88 Civic Wagon 4WD... Will i be able to swap a B18B1 or B18A1 in without any modification??
88CivicWagon
Oct 5, 2003 05:55 AM
racecarpete
May 28, 2002 08:22 PM
