Civic 1.4 Wont Start, Immob Issue?
Old Mar 6, 2013 | 05:05 AM
gtifanboy's Avatar
Default Civic 1.4 Wont Start, Immob Issue?
Hi all.
So here is my problem
Ive got an S reg Honda Civic that isn't starting, it was driving fine then I pulled up and turned it off, got out of the car but then decided to reposition the car (bad parking) but when I tried to start it I got nothing
Ive done a few checks already..
Ignition: Good spark, Good battery
Fuel: Fuel pump priming with key on position II, fuel pressure to the filter, fuel pressure to the fuel rail, NO signal at the injectors?
The engine ran when easy-start was sprayed into the inlet manifold so 99.99% sure its not getting fuel to the cylinder.
My question...
Ive noticed since trying to start it that the green key light doesnt flash anymore, be it putting the key in, cranking, or taking the key out. I wondered whether this could be related as I remember the green key light used to flash in the past (only 2 or 3 flashes the car always started normally).
Another point to note is that my ignition barrel is pretty knackered, no physical damage on the outside but sometimes it can take a long time to get the key turned, sometimes it can take 10 wiggles to get it to the starting position! (it wouldn't make a very good getaway car)
Is the fact that there is no flashing green key light at all good or bad?
Does the immobiliser cut the signal to the fuel injectors or does it cut the fuel pump?
Any advice or information appreciated
Thanks
Old Mar 6, 2013 | 05:31 AM
94EG8's Avatar
Seagull Management
Default Re: Civic 1.4 Wont Start, Immob Issue?
It depends on which Immo setup it is. The '00 - '01 USDM Integra's Immo setup only interrupted the ground for the fuel pump (and were stupidly easy to bypass) Other Honda Immobilzers were considerably more complicated, and if I remember correctly prevented the injectors for firing.
I can't really tell you anymore than that. I can tell you're in Europe or at least somewhere overseas. We didn't have the same equipment here (actually we didn't have any immobilizers on any '92 - '00 Civic here)
Old Mar 6, 2013 | 06:22 AM
gtifanboy's Avatar
Cheers for the reply,
Should have said, Its a standard UK car (IMMO A0 immobiliser maybe?)
Old Mar 6, 2013 | 06:47 AM
94EG8's Avatar
Seagull Management
What year and trim level? (I still wont be able to tell you anything about it, but someone might if you post that info)
Old Mar 6, 2013 | 08:12 AM
gtifanboy's Avatar
Its an S reg 98/99 uk 'illusion' model d14a4
Old Mar 12, 2013 | 07:28 AM
gtifanboy's Avatar
Bump!
Im off to a scrappers today after work to see if I can get a ecu/transponder/lock set but im still open to ideas!
Hank Selig
Jul 2, 2017 12:54 PM
weaponsgrade
Jan 8, 2010 09:55 AM
4tika4
Jan 7, 2010 04:29 PM
EGNA
Jul 12, 2006 03:31 PM
EK k kay
Dec 16, 2004 08:05 PM
