rpms jump to 5k when started up..... please help
Old Oct 21, 2002 | 06:34 PM
HybridEkCivic's Avatar
Default rpms jump to 5k when started up..... please help
just installed a jdm b16a in my 98 dx. When we start the motor, the rpms jump to 5k and fluctuate up and down a few 100 rpms.. we replaced the IACV and believe we have a vacuum leak, but very unsure where it may be. there is one hose ontop of the throttle body that we cant find a home for, but the motor does the same thing when we cap it of start it uncapped... any help is appreciated... Thanks.
[Modified by HybridEkCivic, 11:39 PM 10/21/2002]
Old Oct 21, 2002 | 07:29 PM
PhatOptimo's Avatar
Default Re: rpms jump to 5k when started up..... please help (HybridEkCivic)
Check the throttle cable. Might be a bit too tight and holding the butterfly open.
Old Oct 21, 2002 | 07:39 PM
Default Re: rpms jump to 5k when started up..... please help (Phat_Optimo)
we checked that already. thanks though... its closed completely..
Old Oct 21, 2002 | 07:55 PM
PhatOptimo's Avatar
Get a can of carb cleaner and spray around the IM while the engine is running. Listen for the engine to studder. If it does you've got a leak find out where it is. Also get your vaccum lines in order.
Mrfresh352
Sep 11, 2013 12:21 PM
crxnonvtec
22
Sep 3, 2009 02:52 PM
.I.Need.Money.
Dec 18, 2006 06:28 PM
neoh74
Aug 12, 2004 10:43 AM
ThugLife52
Nov 11, 2002 07:43 AM
