What compression test numbers do I want?
Old Oct 21, 2002 | 05:55 PM
performula's Avatar
Default What compression test numbers do I want?
Old Oct 21, 2002 | 09:48 PM
MrTodd's Avatar
Default Re: What compression test numbers do I want? (performula)
What's the compression ratio?
Usually a Honda motor with it's compression between 9.1:1-9.9:1 should be anywhere between 170psi and 185 psi, these are good strong numbers.
The B16A1 has a compression of like 10.2:1? I don't know, but I'd say you should be okay with numbers above 180psi on the b16&17... Whereas the B18 falls in the catergory above.
I'm not %100 sure on this! All I know is that my setup (z6/y8) yields a 9.8:1 compression ratio: I did a compression test and it's putting out 180 psi on all four. Not too bad...
[Modified by MrTodd, 11:49 PM 10/21/2002]
Old Oct 22, 2002 | 04:37 PM
vtec65's Avatar
Those are good numbers. Ive been told that 150s is the tolerable minimum.
B_Swapped93
Jul 27, 2013 02:51 PM
puma2132
Feb 8, 2009 02:37 PM
Nisif
Apr 12, 2005 09:13 AM
Norcalstoppy
Nov 21, 2002 12:55 PM
