[URGENT] Clutch Problem (I think?)
The clutch pedal sticks on the floor. So I replaced the clutch, after getting no pressure. The pedal still sticks to the floor, as well as the slave cylinder is not pushed in like it should. The slave sticks out (release position). Slave and cylinder replaced. What is wrong?
1993 Honda Accord EX KA5MT
Did you replace the master cylinder? Is your clutch properly bled? Maybe you have a leak in the clutch lines/hose somewhere that is causing your unresponsive pedal. Maybe the plunger between the master and pedal isn't connected (or rattled loose, broke?) securely. Don't start throwing money at things, that is a HORRIBLE way to diagnose an automotive (or any problem for that matter) malfunction.
Posted from Honda-tech.com App for Android
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
thenick
12
Nov 28, 2004 01:35 AM
