Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
Old Mar 2, 2013 | 11:18 AM
UniqueX707's Avatar
Default Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
So my mini-me wont stay on it turn on but it idle 400 around there and it drops and seems to wanna die almost does and then a bit later it does die.i got new plugs and dizzy. my battery isnt good i jump it to start it.. even when it running it dies on me. wonder what can it be. I did the timing correct i belive line up the oil line on the crankshaft gear with the arrow and the cam with the word 'up' and line up with the head
help?
Old Mar 2, 2013 | 11:20 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Mini-me wont stay on?
Describe what parts you used and what car this is n.
Old Mar 2, 2013 | 11:37 AM
UniqueX707's Avatar
b7 block/z6 head
z6 dizzy
y8 pulley
b7 manifold
p28 ecu
Old Mar 2, 2013 | 11:58 AM
Former User's Avatar
Default Re: Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
Start by getting a new battery.
Old Mar 2, 2013 | 12:30 PM
94EG8's Avatar
Seagull Management
y8 cam pulley? Get rid of it, you need the D16Z6/D15B7/D15B8 cam pulley.
Old Mar 2, 2013 | 06:12 PM
UniqueX707's Avatar
Post Re: Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
Already did. Stays on now but wants to die . Also my temp gauge isn't moving. I'm thinking it can be my hose can be off and connect wrong ,yet I doubt. I'm looking for the Honda 92 Manuel book so I can check oem specs
Im also getting code 80
Old Mar 3, 2013 | 07:38 AM
UniqueX707's Avatar
Was wonder how to get rid of code 80??
Old Mar 3, 2013 | 07:41 AM
HondaPartsHero's Avatar
Technical Hero
Code 80 is egr are you sure it's 80? The p28 doesn't look for egr and code 80 won't be thrown on OBD1 ECUs. You sure it's not code 8 for TDC circuit?
Old Mar 3, 2013 | 07:44 AM
UniqueX707's Avatar
Originally Posted by HondaPartsHero
Code 80 is egr are you sure it's 80? The p28 doesn't look for egr.
Yes im pretty sure it 80 i thought it was weird as well. its a auto ecu but converted to 5speed and thats the only code i get 80
maybe it can be 8 it 8 flashs allo the same paces
Old Mar 3, 2013 | 07:47 AM
Technical Hero
Can u post a video of the blinks? If it still throws 80 you might want to try a good known ecu as yours may be defective.
Old Mar 3, 2013 | 07:53 AM
UniqueX707's Avatar
Im pretty sure it is 8 is. my ecu is fine i tested on my friend d16z6 it works fine. My engine get hot really quick, but temp gauge dont work either
Old Mar 3, 2013 | 07:55 AM
Technical Hero
Pretty sure it's 8 or 80?
Old Mar 3, 2013 | 07:57 AM
UniqueX707's Avatar
Code 8 TDC. Takes a couple of cranks so it can turn on 2-4 cranks
Old Mar 3, 2013 | 07:59 AM
Technical Hero
Check the sensor
Old Mar 3, 2013 | 08:00 AM
Technical Hero
Btw what cam and crank pulley are you using?
Old Mar 3, 2013 | 08:09 AM
UniqueX707's Avatar
y8 cam and pulley
Old Mar 3, 2013 | 08:15 AM
Technical Hero
Y8 cam pulley and y8 crank pulley?
Old Mar 3, 2013 | 08:21 AM
UniqueX707's Avatar
no the cam gear is z6 and y8 crank pulley
Old Mar 3, 2013 | 05:32 PM
UniqueX707's Avatar
Icon4 Re: Mini-me - b7 block/z6 head and dizzy/y8 pulley - wont stay on?
Check the sensor
I ended up trying my biddies dizzy on my and went for a test drive no code now so i gunna need a new dizzy. i also got code 21 now. My temp gauge still aint working yet so now it just new dizzy and code 21 and a might need a valve adjustment
cityofcaterpillars
Engine Management and Tuning
Aug 7, 2016 10:44 PM
RoOsKiE
Nov 27, 2013 08:33 AM
tuname420
Mar 27, 2007 08:24 PM
