My theory on bad idle with DSM's and "the hack"
Old Oct 21, 2002 | 05:23 PM
freeplay's Avatar
Default My theory on bad idle with DSM's and "the hack"
Ok, for those of you who have been reading my posts, I have been having trouble with my injectors and S-AFC. It idles bad and hesitates right when I punch it. Anyway, I'm on my way home tonight and one of my spark plug wires falls of my dist (don't ask). Luckily, I had about 1/4 mile to my house. When I got home, I noticed my car was running the exact same way as when the DSM's are in. So, my theory is that one of my injectors is not working even though they are rebuilt. Everyone tell me if I'm retarded or somewhat smart. Is there a way to test my DSM's? Thanks
Old Oct 21, 2002 | 05:48 PM
freeplay's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (BoostInBoi)
No input? Damn. Come on fellas, I know you can think of something
Old Oct 21, 2002 | 05:52 PM
pelotudo's Avatar
<--Wants to know also, back up...
jB
Old Oct 21, 2002 | 06:05 PM
sutrusu's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (PelowisheshewascoolTudo)
it's not just you who has the problem... so i dont think everyone who has that problem has a faulty injector.
Old Oct 21, 2002 | 06:16 PM
ion_four's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (sutrusu)
but, I doubt it's something fundamentally wrong with the hack. my car idles perfectly fine with a custom circuit that is less adjustable than the 'hack'. it's all in the tuning; I'm sure I could make my car idle crappy if I wanted to it might also be because you are running rich/bad o2 sensor. What fuel pressure are you running?
as a side note: do not boost if you suspect one of your injectors is not working! you are killing a cylinder...to test it, partially, let the car idle and place the blade of a screwdriver on the injector and put your ear on the handle, thus you should hear a clicking sound from each injector, if not; one is gone.
Old Oct 21, 2002 | 06:25 PM
freeplay's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (ion_four)
Thanks, I'll give that a shot. I haven't driven with my DSM's installed, just idled. I was sure not to boost on my way home with my CEL. Thanks though.
This is a problem we have to get figured out since there's numerous people with it. Is it a software (S-AFC, ecu) or hardware (injector, wiring, resistor) problem.
BUMP this topic
[Modified by BoostInBoi, 3:39 AM 10/22/2002]
Old Oct 21, 2002 | 06:59 PM
Jared's Avatar
so its running on 3 cylinders? start pulling off plug wires one by one with the engine running until you find one that doesn't drop the RPMs when you pull the wire off. then youve found your dead cylinder.
Old Oct 21, 2002 | 08:06 PM
freeplay's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (Jared)
Good thinking.... I'll go try it. Any other ideas? Keep em coming!!!
Old Oct 21, 2002 | 08:15 PM
CzanSOHC's Avatar
you should try to cut them back to -45% at idle, so how that goes.
Old Oct 21, 2002 | 09:01 PM
freeplay's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (Vertigo)
Ok everyone....I just went out and put in my 450s once again and did the screwdriver trick. Turns out one of my injectors is not clicking. So, I am hoping that is the only problem. I suggest you all try it too and let me know what you think. Maybe I'm totally wrong. Thanks
Old Oct 22, 2002 | 02:34 AM
boostinb18's Avatar
andif your car is idleing bad with the 450s try to raise the 1k setting to about -18% and 2k setting to about -21% thats what i did and it runs much smoother....... and you wont boost that low so it wont throw a cel.
good luck wiht that one injector!!!
ohh yah one of my injectors is cracked on the tip... i believe its called the plunger housing, will that cause a leak??? thanks!
Old Oct 22, 2002 | 01:30 PM
boostinb18's Avatar
thanks..... yah im gonna send mine off when i pull my turbo off! i think they need a rebuild anyways!
Old Oct 22, 2002 | 01:56 PM
BoostedH23a1's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (boostinb18)
vertigo u like those injectors???
Old Oct 22, 2002 | 03:47 PM
ahha but they work...
Old Oct 22, 2002 | 09:43 PM
Stupid Ass's Avatar
Great information guys... Thanks!
Old Oct 23, 2002 | 03:09 AM
kshymkiw's Avatar
Well feel if your injectors are firing! All you have to do is out your finger on the plastic outside and you will be able to feel it fire. Try throwing in some Injector cleaner in your fuel tank as well.
Old Oct 23, 2002 | 08:18 PM
dmotoguy's Avatar
Default Re: My theory on bad idle with DSM's and "the hack" (kshymkiw)
so are you just going to order one more injector riley? have you been able to boost yet with your stock injectors?
s032105k
Apr 12, 2011 07:56 AM
soopafly828
Mar 15, 2003 07:17 AM
