99 accord ex 4cyl blows smoke
Old Mar 2, 2013 | 09:14 AM
murphydennis17's Avatar
Default 99 accord ex 4cyl blows smoke
hello everyone I have a 99 Honda accord ex 4 cyl and when I get on it, it blows smoke not sure the color b/c im in the car and can oly see the smoke in my rear view but any suggestions on what to check. or do? is it normal?
Old Mar 2, 2013 | 09:27 AM
jdowen2's Avatar
Default Re: 99 accord ex 4cyl blows smoke
If your coolant level hasn't changed it's probably oil. Do a compression test for starters.
Old Mar 2, 2013 | 09:36 AM
okay can you give me an idea on what to look for? if my distributor o ring is bad or the v tech gasket would that do it? cause it to smoke?
Old Mar 2, 2013 | 10:34 AM
jdowen2's Avatar
Smoking exhaust is usually caused by worn piston rings or worn valve guides to name a few. How many miles on your car? Could also be a PVC issue.
Old Mar 2, 2013 | 11:23 AM
92 civic ex 4dr's Avatar
Jdowen2 means pcv. Like he stated most likely the valve guides/seals. Not UN common for those engines to burn oil due to bad guides/seals for the valves.
As far as where to start. Do a compression test first. It's the cheapest.
While I'm thinking of it. Pull the intake tube off of the throttle body and open the butterfly. If you see a lot of oil in the throttle body, on the butterfly, in the manifold and even in the intake tube, you have blow by and need valve stem seals.
How many miles on the engine?
Posted from Honda-tech.com App for Android
Old Mar 2, 2013 | 11:33 AM
220,000
Old Mar 2, 2013 | 11:34 AM
is the vavle guide/seal an "easy" fix?
99turboaccord
Feb 27, 2019 02:31 AM
Redprelude98
30
Jul 21, 2009 01:21 PM
dfoxengr
Oct 27, 2008 11:29 AM
HybridBB6
May 14, 2007 02:36 PM
xlusiveracer
Sep 7, 2005 04:13 PM
