Gauges in the S-Type
Old Oct 21, 2002 | 05:16 PM
Archidictus's Avatar
Unceasing Measure
Default Gauges in the S-Type
It's funny how life can thwart you in even the simplest of tasks. So my friend and I are attempting to install two cobalt gauges. The pillar is fine, the gauges look beautiful and everything is cool. The problem? Even though we've spliced into perfectly viable grounds and power lines, we've got no juice.
If anyone has installed gauges (autometer, btw) in their car, where did you hookup the power and the ground? thanks in advance, fellas.
Old Oct 21, 2002 | 08:26 PM
TypeS Jay's Avatar
Default Re: Gauges in the S-Type (Archidictus)
If you want a solid power+, and a solid ground-, go to the fuse box under the driver side dash for the power. Then go to the chassis for the ground, or the neg- on the battery. If you dont want to run it through the firewall then do it this way. Hope this helps.
Old Oct 22, 2002 | 04:54 AM
GoodKnight's Avatar
If you need a hole in the firewall, there's one behind the glove box.
Old Oct 22, 2002 | 07:05 AM
Unceasing Measure
Default Re: Gauges in the S-Type (GoodKnight)
thanks for the help guys. we're very familiar with wiring and such, and we're sure that we can make it work, but the damn connections just seem to be ******* us at every turn. we try again this afternoon...i'll keep ya'll posted on the results.
thanks again fellas
Old Oct 22, 2002 | 07:12 AM
00R101's Avatar
OK - First get a voltmeter. Measure the power at your "good" power to your "good" ground. Got 12 volts? If no there's your problem.
Step 2 - get a 12volt power supply from Radio Shack and hook your gauge to it in the house. Does it work? If no then there's your problem.
Step 3 - Don't become a rocket scientist quite yet.
Old Oct 22, 2002 | 05:27 PM
Unceasing Measure
Default Re: Gauges in the S-Type (00R101)
you crack me up. if I needed smartass comments, I would've addressed that in the thread title. we found out what the problem was: shitty 3M wiretaps that weren't actually connecting the wires. the cobalt lighting thing still isn't working, but we'll be troubleshooting that another time.
anybody ever tapped the fuel system of the RSX-S? it's required to install the fuel pressure gauge.
Old Oct 22, 2002 | 05:53 PM
GoodKnight's Avatar
I've tapped the fuel line for my NX wet kit. Take the i-VTEC plastic cover off the im, and you'll see the fuel rail. Follow it down, and by the firewall there should be enough slack in the line for you to tap into it.
Old Oct 22, 2002 | 06:42 PM
Unceasing Measure
thank you kindly
xelloss
Nov 10, 2008 01:50 AM
ITRnorway
May 26, 2007 02:46 PM
huge230
Apr 22, 2007 06:32 AM
XxslayerxX
Feb 1, 2004 08:33 PM
y2kintegra
Jul 29, 2002 01:05 AM
