Help! idling confusion?
Old Feb 28, 2013 | 03:34 PM
miguey310's Avatar
Default Help! idling confusion?
Hi, well i recently had my engine replaced on my 2000 civic ex and i've started getting high idling and random cel and i check if i had a vacuum leak in which i ruled out that my intake manifold gasket was no good anymore. so today i replaced that im gasket thinking it was gonna be fixed and it still idling high and the odd think is that normally its at 1500 rpm and once i turn on the AC it goes down to 1000 rpm. What should i check for?
Old Feb 28, 2013 | 10:12 PM
miguey310's Avatar
Default Re: Help! idling confusion?
Old Feb 28, 2013 | 10:21 PM
B_Swapped93's Avatar
Clean you'r IACV to start/Adjust the idle screw IF needed.. also what's the code you're getting
Old Feb 28, 2013 | 10:30 PM
jbpnoman's Avatar
Step 1: Pull the code, post it, then reset your ECU. There's a how-to in the FAQ's sticky.
Old Mar 1, 2013 | 06:32 AM
miguey310's Avatar
already have and nothing
i'm getting po325
which is the knock sensor
Old Mar 2, 2013 | 12:22 PM
miguey310's Avatar
help!
Old Mar 2, 2013 | 12:28 PM
Former User's Avatar
What engine did you install?
Any CEL codes thrown?
If you remove the air intake system and then use your finger to cover the port/hole inside the throttle body leading to the IACV, does the idle speed drop?
Old Mar 2, 2013 | 06:47 PM
miguey310's Avatar
I'm using a direct replacenment of a y8
i'm getting code po325
which is the knock sensor but idk how can effect the idle
Hoessaygodinez
Feb 1, 2017 01:44 PM
dragon_lowrider
Sep 22, 2010 10:55 PM
88si
16
Jul 16, 2010 03:20 PM
intekragsr
May 22, 2003 03:32 AM
Prevail
Feb 28, 2003 07:19 AM
