Honda CR-V & Element 2WD & 4WD Element & CR-V
Windows wont roll down
Old Feb 27, 2013 | 09:53 PM
swordofdoom's Avatar
Default Windows wont roll down
My drivers side and rear passenger side won't roll down. I've replaced the drivers side regulator no go. Replaced the master power window switch and still the same thing. Haven't checked the rear passenger side. Any suggestions on what could be the cause?
Old Feb 28, 2013 | 05:34 AM
LDForget's Avatar
Default Re: Windows wont roll down
is there power at the switch?
Old Mar 2, 2013 | 02:15 AM
lazlong's Avatar
^^ He should have power because 2 of the windows work.
The usual suspects are a bad master switch and broken wires in the wire boot. Since you've already replaced the master switch look for broken wires in the wire boot in the door hinge area.
You can also test for voltage output from the master switch. On the non-drivers doors the circuit usually runs through the window switch so, you may need to test for voltage (input and output as needed) at that switch too.
Old Mar 2, 2013 | 05:17 AM
LDForget's Avatar
he never said that any of them work, he said that 2 of them dont work.
Old Mar 6, 2013 | 10:33 PM
Yeah passenger front window works, and the rear door behind the driver works. This is odd.
Anybody got the wiring for the windows or any clue as to which wire goes where for the regulators? I already checked the Fuse for the windows and its still in good shape.
Old Mar 17, 2013 | 06:16 AM
WolfKnife's Avatar
Maybe a cont test on the wires, make sure you have a circuit. Just spitballin here.
Old Mar 17, 2013 | 06:50 AM
Kevin Lu's Avatar
You should also try to see if the motor's still good. When we acquired my CRV, none of the windows were working. We spent a good deal of time trying to check the wiring only to find out that the motor's corroded inside already. If you're lucky, you could try cracking open the power window motor and clean it up using WD-40. It's a pretty simple procedure, just be ready to spend around an hour and a half or so on it.
Old Mar 18, 2013 | 09:22 AM
crvfan's Avatar
Power from a battery directly to the motors will tell u if the motors areworking
Robb Ellis
Mar 9, 2019 04:39 PM
cshipman
Oct 16, 2018 06:42 AM
ArtyTheKid
Mar 18, 2015 04:56 AM
einzelherz
Aug 26, 2013 06:41 AM
