O2 sensor keeps failing
Old Feb 26, 2013 | 07:13 PM
Ken Knowles's Avatar
Icon3 O2 sensor keeps failing
I have a 91 honda civic. 2 weeks ago, the CEL went on. It was a single red flash on the ECU. which is the O2 sensor. I replaced the sensor and cleared the Code by removing the battery overnight.
Today on my way home the CEL went on again, same code.
What could be causing this?
it leaks some oil from the valve cover, and I recently replaced the head gasket. When I start the car up it smells rich.
Old Feb 27, 2013 | 05:30 AM
rustbucketrex's Avatar
Default Re: O2 sensor keeps failing
O2 Sensor is not bad, you have a sensor that is doing it's job. You will need to fix your rich running car.
Old Feb 27, 2013 | 05:44 AM
Where is a good place to start trouble shooting? Could the dashpot tandem control valve cause it to run rich?
Old Feb 27, 2013 | 11:42 AM
When you changed your head gasket, you may have put the timing belt back on one tooth off. Check your cam timing then you may want to check your ignition timing.
Old Feb 27, 2013 | 07:49 PM
Today I chck the voltage to my tandem valve control soleniod. I'm missing the 12 volts. Could that mak the O2 go out. Also the build-up on the O2 was white.
Old Feb 27, 2013 | 07:58 PM
K-Murda12's Avatar
I think I am having the exact same problem. Except one time I drove through rather large puddle. (Unintentionally) Car acted up for a couple hours. Parked it. Next day worked fine...... weird.
Old Mar 1, 2013 | 03:57 AM
Wouldn't it run really bad if I was off one tooth? This car drives well, sounds great. I pulled the newer O2 sensor yestrday. it looked like new. No build up on it. I have ot had the CEL light on since I replaced it. But, this was the same with the last O2 sensor.
Old Mar 1, 2013 | 06:52 AM
grog's Avatar
You could have a problem in the O2 sensor wiring or it could be running rich as mentioned.
Test your fuel pressure regulator, make sure its ok.
Look towards the bottom for testing: http://www.hondacivicforum.com/forum...6-issue-61252/
Also test your O2 sensor curcuit: http://www.justanswer.com/honda/11xt...otor-into.html
lopa
Apr 11, 2013 06:35 AM
I has a Teg
Oct 19, 2008 03:48 PM
importdreamer
May 26, 2007 06:58 PM
boost fed ls
Aug 31, 2004 07:45 PM
DumpedSi
Aug 23, 2003 09:55 AM
