ef battery relocation?
What kind of battery did you use?
It's not exactly safe to just move an acid battery to the rear of the car, it should be in a sealed battery box that vents outside the car.
its a exide racing/commercial battery. its too big for my front battery location bc it rubs my clutch cable. I ran one gauge amp cable with a inline fuse block and so far ignition clicks over and relays click. I'm making sure the gauge bc after engine is rebuilt dont wanna burn my car down.
I had a crx with a relocated battery using 0 gauge wire, never had a problem with it. I would probably go that route. And x2 on the sealed or vented battery idea.
