E85 na compression ratio question
I'm building a very high hp na b series build and my final piece to the puzzle is compression.This e85 thing is new to me and I understand the benifits of using it and its readily available for me to use.I was going to be running 13.0:1 cr before I decided to make the switch to e85.What would be a high compression number that I could still use and be somewhat decient on the street?
Before anyone asks the questions about my motor setup here is a rundown on some of the basics.
Dart block at 86mm
Endyn full na built head
Kinsler itbs port matched via PDF to the head.55mm
Bisi header till I spring for a Myers unit.
92mm scat 29lb crank
Crappy eagle ls rods.
I hope I have given enough information.i would just like a little insight.
Thanks
Dart block at 86mm
Thanks
I am pretty much looking for what is the max I can go.
I was going to pick up a set of grp rods but the car will be driven so i am staying away from the aluminum rods.
The camshafts used are pro 3s and I will also be comparing ddtechs reapers.the intentions with the build are simple,run 11s on the drag strip and be driven there an back.also maybe a little auto x.
Your rod choice will depend on your piston rod combo. Are you running a 5.394 rod or the 5.531 rod? 5.531 rod only has two option without going custom, Crower and Eagle. The 5.531 eagle rods should weight around 535 w/bolts
Im running them in my 89x81.5 setup. They work good for me. I appreciate the light weight assembly on the road course. But they are only rated to 400hp. Fine for me, but think about the future of your motor. If u find your self not hitting your ET goals, would u go n2o? This may put your setup close to the threshold. Everyone knows the eagles are a safe bet no matter what. And in drag racing how much whp are you really gonna lose with the eagles... only reason I would get **** about rotating assembly is for road racing and such.
That's a good point cause a 100 shot is going to happen and if those carrillo a can only hold that much then I would be very close indeed to the breaking point.
I built my motor originally to run on both e85 and 91 but I regret that now (12:1 c/r). I should have just gone higher and planned on running e85 all the time. I currently always run e85 since its annoying to switch fuels and I don't have to worry about detonation at all. I have been itching to build/tune a 13:1 + motor on e85. I keep trying to talk my customers into doing it so I can see how it turns out. Just go for itbut make sure you get big injectors like 750 or bigger
Here is a good thread on e-85 for everyone ...
https://honda-tech.com/forums/showth...1812349&page=4
Full Race A6
23
Jul 28, 2004 04:18 AM
