Compression Test: Weird results. Wet & Dry
Old Feb 24, 2013 | 06:48 PM
Team_Coast978's Avatar
Icon2 Compression Test: Weird results. Wet & Dry
B17 block
B16a2 pistons & Head
Dry
1 - 245
2 - 175
3 - 235-240
4 - 250
Cracked piston maybe ? This is a fresh build .. Under 1000 on the block.... feeling very confused, can't be the rings ..
Wet
1 - 300-320 (off the gauge)
2 - 270
3 - 250
4 - 290-300
I was thinking maybe I put too much oil in for the wet test, but I put about the same amount in all 4 so why were the results so off if they were within 5% in the Dry test (besides cylinder 2) .... I just need to know what's going on, some words of advice would be nice. what could it be ? what do you guys think ? Thinking of scrapping an starting something new ...
Old Feb 25, 2013 | 05:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: Compression Test: Weird results. Wet & Dry
I would try another compression test gauge, to eliminate it as the possible problem. 94
Old Feb 27, 2013 | 08:21 AM
h22-eg-hatch's Avatar
How many times are u cranking. Per cyl
Do all 4 cyl back to back 2-4 times.
Same reading.?
Old Mar 1, 2013 | 03:46 PM
i was cranking about 4 maybe 5 times
Uncle Ben's
Dec 8, 2007 12:21 PM
godnf8
Feb 12, 2007 07:33 AM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
gsr~hatch
Apr 17, 2003 03:19 PM
