95 civic ex ignition switch issues
Old Feb 22, 2013 | 05:25 PM
Nuckinfutz's Avatar
Default 95 civic ex ignition switch issues
The civic starts, and runs, but only if the key is in position three. If it comes out of position three, the car cuts off.
It's definitely not the fuel pump, fuel pump relay, distributor, plugs cables, coil, starter or battery. I took the liberty of opening the ignition switch on the back of the ignition key cylinder to verify the part is in good working order, I can't find any fault in the ignition switch.
Any help would be wonderful.
Old Feb 22, 2013 | 05:35 PM
B_Swapped93's Avatar
Default Re: 95 civic ex ignition switch issues
Look on the side of you ignition cyl there should be marks 1 2 3(shown like this I II III) the car should only be running in the 3(III) postion. maybe i missread you'r post but it sounds like you expect the car to run/idle in 2(II) and 1(I). not the case two is the accesory postion windows sunroof stuff like that and one is for the basic radio.
Old Feb 22, 2013 | 05:42 PM
Nuckinfutz's Avatar
yea, it cuts off in position two unless it's held in position three (the starting position).
Old Feb 22, 2013 | 05:59 PM
ok so you have to hold it(in postion 3) for the car to actualy remain running ?
Old Feb 22, 2013 | 06:04 PM
Nuckinfutz's Avatar
Yes.
Old Feb 22, 2013 | 06:31 PM
Former User's Avatar
Buy the electrical part of your ignition switch and replace the bad one. I've seen them sold on eBay for about $50.
Old Feb 26, 2013 | 11:32 AM
Nuckinfutz's Avatar
So, I replaced the ignition switch, and now the car wont even turn over.
While taking the original part off, I noticed there was some extra cables that ran off to some other unidentified electrical components. The issue with the ignition switch is that the position two connector/cable is receiving no charge, so I'm assuming there is a ground somewhere, or one of these electrical parts that I cannot ID must be broken. *unenthused yay*
I can post some photographs, and if you can tell me anything that could help, I may just mail you some brownies. The good kind.
Old Feb 26, 2013 | 01:31 PM
cvcrcr99's Avatar
Did you test the ignition switch with a multimeter?
rizzuto_usmc
Oct 21, 2013 12:30 AM
team 15
Mar 7, 2011 12:54 PM
bushrat
Jan 16, 2005 09:21 AM
BlkGSR
Mar 7, 2004 06:28 AM
