Why would one block off the EGR, FITV, and Air boost valve?
Old Feb 21, 2013 | 08:05 PM
qhiggy's Avatar
Default Why would one block off the EGR, FITV, and Air boost valve?
I found online a kit to block off all three, is there any benefit? or what is it for? I drive a 1995 honda accord ex 2.2 vtec.
Old Feb 21, 2013 | 11:16 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Why would one block off the EGR, FITV, and Air boost valve?
On a street car, no.
or what is it for?
Deletion of said components, not for power but for simplification by reduction of components on an offroad vehicle.
Installing those block off plates on a street car would require retuning of the ECU to be properly done on a dyno, and in the end would net you F all in power gains.
Old Feb 22, 2013 | 02:00 AM
NZXTInerTia's Avatar
Removing the EGR would require a retune. I never had a boost valve, I removed my FITV because you simply don't need it (the IACV can easily handle the load), and the EGR when removed keeps the manifold cleaner, cooler, and more simple to service. But, like I said previously, will need a retune.
Old Feb 22, 2013 | 08:06 AM
h22a2JZGTE's Avatar
^everything said above by those 2 essentially. i've been running a block off plate instead of the egr, its soul purpose was to cool the intake side of the combustion chamber when cruising(to help prevent the air/fuel mixture from pre-igniting caused by the extreme combustion chamber temps aka engine knock/ping). without it your air/fuel mixture wont be disturbed by the relativly hotter recirculated exhaust, thus in the right cenario, will result in a slight power gain. but when i deleted mine, it caused my engine to have alittle hesitation during acceleration between 3-4500rpm but pulled nice and strong up top. a good tune brings out the best of what this modification can do.
Old Feb 22, 2013 | 08:53 AM
JDM95Honda's Avatar
You coulkd also run a higher octane to help aid in getting rid of the predetonation
Old Feb 23, 2013 | 10:16 AM
MAD_MIKE's Avatar
MM Gruppe B
Common misconception.
The recirculated gases do not cool down the combustion temps. The mixture is diluted with the spent inert gases, this diluted mixture will not create the same power levels. Since not as much energy is created, not as much heat and pressure is created during combustion which reduces the creation of NOx emssions in the primary combustion sequence. However, since EGR is only activated during part throttle operation full power is not required. At WOT EGR is not activated, thus does not affect power output usage.
There is no scenario. Simply deleting the mechanical side of the EGR system is going to cause loss of economy, and cause preignition issues. Timing is advanced during EGR operation to complete combustion.
That hesitation is due to incorrect removal of the EGR system. On a street car it is pointless to remove EGR, the work and money spent to properly delete it will not net one with any meaningful gains.
Correct deletion of the EGR system will only net simplification of the onboard systems. Nothing more nothing less on an otherwise stock to mild street car.
Pointless. Even if the higher octane reduces audible detonation the timing and fuel tables are still incorrect.
jdmchinoCDN
Sep 5, 2010 03:21 PM
Boostin_GSR
Apr 4, 2007 12:21 AM
Tex Blackwell
Jul 20, 2004 03:18 AM
abeaujuin
Dec 22, 2003 11:50 AM
