Upper control arm replacement.
Old Feb 23, 2013 | 09:51 AM
The Jar's Avatar
Default Upper control arm replacement.
Hey,
I am about to replace both front upper control arms. The ball joints are getting worn out.
The Haynes manual says to remove the coil/strut assembly for that.
Is it really necessary? It seems like I can do it without this step?
Are there any other small parts that I need to order that wont come with the upper arm?
Accord EX Coupe 99.
Thanks a lot!
Old Feb 23, 2013 | 09:56 AM
NZXTInerTia's Avatar
Default Re: Upper control arm replacement.
You don't have to remove the strut, just remove the two bolts inside the engine bay. Then use a pickle fork or a pitman arm puller to remove the bolt end of the ball joint from the knuckle.
Old Feb 23, 2013 | 10:22 AM
The Jar's Avatar
Thanks!
TheRookie74
Sep 17, 2014 05:39 AM
Vagitarian
22
May 30, 2012 05:06 AM
blueBB4lude
11
Jul 30, 2009 09:14 AM
driveslow
Mar 6, 2009 04:53 AM
^Sammy]!.
Sep 22, 2003 05:47 PM
