which block to use?
Old Dec 22, 2003 | 10:02 AM
abeaujuin's Avatar
Default which block to use?
I have a 94 accord EX VTEC. Should I get a CRV block or a F22 Block. I heard the CRV block can handle 20lbs of boost with stock internals. is this true? Will it work with my F22 VTEC head?
Old Dec 22, 2003 | 10:03 AM
ekb18c's Avatar
Default Re: which block to use? (abeaujuin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abeaujuin &raquo;</TD></TR><TR><TD CLASS="quote">I have a 94 accord EX VTEC. Should I get a CRV block or a F22 Block. I heard the CRV block can handle 20lbs of boost with stock internals. is this true? Will it work with my F22 VTEC head?</TD></TR></TABLE>
Nope.. Stock b20 can't handle 20lbs with stock internals for too long.
If you have a 94 accord, why not build up a h22 block?
Old Dec 22, 2003 | 10:07 AM
abeaujuin's Avatar
Default Re: which block to use? (ekb18c)
I was told that an F22 block can be built as well. I got a used F22 Block. I was getting ready to built it will this be able to work.
Old Dec 22, 2003 | 10:09 AM
ekb18c's Avatar
If you are going to build a block why not build a block that can produce more power? I wouldn't waste money on building a f20 block because at the end, you will be unhappy with the amt of power it produces.
Old Dec 22, 2003 | 10:13 AM
abeaujuin's Avatar
What block do you recommend? and where can I get it from?
Old Dec 22, 2003 | 10:16 AM
Kwuaymaikrup's Avatar
Go with an H22 and I am sure you could find one on here.
Old Dec 22, 2003 | 10:17 AM
ekb18c's Avatar
h22 block, which is a 2.2L Vtec motor from a prelude.
At the end you will have spent more money on the h22 block but you will be happier.
Old Dec 22, 2003 | 10:22 AM
abeaujuin's Avatar
The F22 is a 2.2L as well. I was thinking about the H22 but because the AC would not work with the Drag turbo kit, I didn't go that route. But how much more power does the h22 block has then the F22?
Old Dec 22, 2003 | 10:23 AM
The HP all depends on what you do to the block. The H22 has way more aftermarket support than the F22.
Old Dec 22, 2003 | 10:34 AM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abeaujuin &raquo;</TD></TR><TR><TD CLASS="quote">The F22 is a 2.2L as well.</TD></TR></TABLE>
Ah yes, but h22 is a dohc while the f22 is a sohc.
Well, how much power are you planning to make?
Old Dec 22, 2003 | 10:38 AM
abeaujuin's Avatar
True, but I want to stick with the SOHC, because I have it. Why not port and polish it and build the block to handle more boost? It would be cheaper for me that way.
Old Dec 22, 2003 | 11:47 AM
eG_6ix's Avatar
it seems like you already have the answers to the questions you ask, no point in asking advice if you dont want to use it
Old Dec 22, 2003 | 11:50 AM
abeaujuin's Avatar
Default Re: which block to use? (eG_6ix)
Well I am not an expert, but I have been doing research. Everyone has there opinons on how or what to do. I just wanted to know if the CRV is better for boost then the F22.
eg:R
Apr 19, 2014 08:56 AM
freakasis
Jan 31, 2010 06:36 PM
wesley_925
Jun 29, 2008 12:16 AM
Rod.
Sep 12, 2003 10:51 PM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
