View Poll Results: Which cools better
All alliminum radiator
100.00%
Alliminum with plastic end tanks
0%
Voters: 2. You may not vote on this poll
What cools best
Old Feb 20, 2013 | 06:57 AM
JDMmadness's Avatar
Icon2 What cools best
I have a ef sedan and I'm about to buy a 85 vw scirocco radiator. Not sure if I should just get oe replacement that's alliminum with plastic end tanks. Or spend about 100 more on the all alliminum rad. Any suggestions ? Which actually cools best? Is it a significant difference
Thanks in advance
Old Feb 20, 2013 | 08:00 AM
snobordboy's Avatar
Moderator
Default Re: What cools best
Why would you go to a Rocco rad, unless you are trying to tuck it between rails on the rad support?
Generally an all aluminum rad will not have issue with the caps separating, and a thicker core will hold more fluid, so it can hold a more stable temp. One thing to look at is how the core is constructed, as all rads are not created equal. Koyo and Fluidyne both make good quality rads.
Old Feb 20, 2013 | 08:35 AM
JDMmadness's Avatar
I'm going with that rad to tuck it under the support and get it away from my turbo
Old Feb 20, 2013 | 08:46 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I like all aluminum just because they aren't as likely to leak like ones with plastic ends. If they are both single cores then they are likely to be about the same cooling wise. A dual core has larger capacity so it is more efficient keeping the rad. Fluid cooler.
JDMislander
Welding / Fabrication
Mar 20, 2010 08:18 PM
StraitRunna
Jan 18, 2009 07:29 PM
BodyKits NW
Jun 23, 2006 01:06 PM
1fastVX
19
Jun 28, 2005 02:55 PM
