interior leaking HELP!
Old Oct 21, 2002 | 12:29 PM
t o m's Avatar
Default interior leaking HELP!
so this is the situation,
over on the front passenger side on the floor, its soaked. Does anybody know wat kind of fluid lines run under the chassis. It smells like water but has a look of like motor oil, but isnt as consistant as motor oil. anybody got any suggestions?? thanks in advance.
Old Oct 21, 2002 | 12:34 PM
.Beaver's Avatar
Bloody Beaver
Default Re: interior leaking HELP! (TOManegi)
it might be something from the heater core
Old Oct 21, 2002 | 01:00 PM
Neptune's Avatar
Was it raining? If it was check up top by the door. If you notice any seals that are not fully covering the roof fill it up with some caulk or anyhting else that will work. I had that problem, as for the liquid I think it is just all the grime from your carpet seeping out into the standing water. If it wasn't raining then, hopefully someone else wil know.
Old Oct 21, 2002 | 02:50 PM
t o m's Avatar
Default Re: interior leaking HELP! (AmericanWagoner)
its not the seals in the door cuz it hasnt rained in months
Old Oct 21, 2002 | 02:52 PM
Bondel Slo's Avatar
Sounds like a heater core or an AC box drain tube. Does it happen only when either the heat or AC is on?
Old Oct 21, 2002 | 04:47 PM
t o m's Avatar
Default Re: interior leaking HELP! (Bondel Slo)
i think so. good stuff guys ill chek it out tonite
any more suggestions are more than welcome thx
[Modified by TOManegi, 5:48 PM 10/21/2002]
Old Oct 21, 2002 | 05:38 PM
t o m's Avatar
to the top
Old Oct 21, 2002 | 06:11 PM
t o m's Avatar
t t t
Old Oct 21, 2002 | 07:04 PM
sleeperb's Avatar
sounds like a clogged a/c drain tube. if you uncoil a clothes hanger you can stick it in the tube and usually get out whatever is in there. good luck.
91accordcandy
Aug 15, 2014 03:49 PM
Nessa Sushi
May 22, 2012 05:51 AM
harveyy
Mar 26, 2009 04:18 PM
BlueIntegraBoy
Aug 1, 2008 09:37 AM
Josh Carr
May 12, 2004 08:10 AM
