interior leaking HELP!
so this is the situation,
over on the front passenger side on the floor, its soaked. Does anybody know wat kind of fluid lines run under the chassis. It smells like water but has a look of like motor oil, but isnt as consistant as motor oil. anybody got any suggestions?? thanks in advance.
Re: interior leaking HELP! (TOManegi)
Was it raining? If it was check up top by the door. If you notice any seals that are not fully covering the roof fill it up with some caulk or anyhting else that will work. I had that problem, as for the liquid I think it is just all the grime from your carpet seeping out into the standing water. If it wasn't raining then, hopefully someone else wil know.
Re: interior leaking HELP! (Bondel Slo)
i think so. good stuff guys ill chek it out tonite
any more suggestions are more than welcome thx
[Modified by TOManegi, 5:48 PM 10/21/2002]
sounds like a clogged a/c drain tube. if you uncoil a clothes hanger you can stick it in the tube and usually get out whatever is in there. good luck.
