Engine Block&Transmission restoration
Old Feb 19, 2013 | 09:47 AM
woodenchef's Avatar
Default Engine Block&Transmission restoration
Hi so I am going to be restoring my engine and transmission. I believe I got the right products to do the clean up, but I am not sure about how to get that nice aluminum shine back again. I saw one guy do it with Car Brite aluminum spray, but I can't find that product anywhere. Any big automotive stores that sell it. I also saw Canadian tire had engine Enamel sprays in different colors. There was an aluminum one but it says you need engine primer if spraying on bare which which the block is bare metal right?
Old Feb 20, 2013 | 09:33 AM
dan.'s Avatar
Default Re: Engine Block&Transmission restoration
go to walmart and buy a black and decker crimped wire wheel attachment for a drill. they are like 4 bucks and come in different shapes and sizes. Go over everything with the wire wheel after you spray the degreaser, it will make cleaning alot quicker and loosen up stuff you cant get with your hands,also taking off any rust you may have. Finally, polish with some mothers aluminum polish or some sort of metal polish, or jewelers rouge. soak any rusted parts you may have in vinegar, i soaked all my brackets and bolts the polished them and painted with engine enamel
Old Feb 20, 2013 | 05:10 PM
Hidenplanvew's Avatar
Napa has some alum brightner stuff that works very nice but make sure to take it off in the 30 sec for it turns alum grey
Old Feb 20, 2013 | 09:30 PM
MustardCat's Avatar
If you want to paint it, get a hold of VHT "Cast Aluminium" paint. If you mask off bolt heads plus anything that shouldn't be painted it looks really good and people often don't realize it's paint. Example:
EkEire
Feb 3, 2009 12:44 PM
teddy_dc2
Oct 6, 2007 06:37 PM
locomex4life16
Jul 5, 2004 07:13 AM
92DSeries
24
Jul 1, 2004 09:21 AM
LilDevil
23
Apr 18, 2002 09:29 AM
