95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
Old Feb 19, 2013 | 08:46 AM
beastmodeej2's Avatar
Default 95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
ok so i did i z6 swap in my dx coupe but now i have codes 6 10 19 and my car have a hard time starting i dont know where to start the wiring and everything seems to be correct and also my battery seems to be draining rapidly fast too the alt is ok had it tested...
Old Feb 19, 2013 | 11:52 AM
Somalie187's Avatar
Default Re: 95 civic NEED HELP
There may be a draw in the system. I do not know how to check this... But your battery may also be dying.
Old Feb 19, 2013 | 12:16 PM
Former User's Avatar
Default Re: 95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
Reset the ECU to see whether any of the codes repeat.
What ECU are you using?
Do you have a manual transmission? Code 19 indicates that your ECU is for an automatic transmission.
Old Feb 20, 2013 | 03:00 AM
yeah its a manual i cleared most of the codes now im stuck on code 19 which means i just gotta get a new ecu oh and im running a p28
Old Feb 20, 2013 | 03:38 AM
94blkturbo's Avatar
you don't have to get a new ecu. if you have a little bit of soldering skills you can take out R18 and R17 then put a jumper wire in place of R18. just be sure to use a low watt soldering iron.
Old Mar 1, 2013 | 05:23 AM
where do i jump the jumper wire too?
BoostAndBoobs
Apr 21, 2016 04:53 AM
blaze_125
Sep 10, 2008 09:39 AM
jimmy o.
12
May 14, 2008 04:16 AM
-[95cxhatch]-
Aug 1, 2006 06:10 PM
skaterdx
Aug 26, 2004 11:11 PM
