Auto-Tensioner Failure
not really a bad noise. At idle it sounds like something is slapping around and its definatly a belt. As long as you havent engaged vtec on a broken tensioner and the gears aint slip u should be ok. A costomer came in with a broken tensioner and drove it from his house to our shop and there was no damage. But the best thing is to convert to 2.3 tensioner, and its really easy and makes for soo much less work down the road. By the way all our 2.2 run 2.3 tensioners and none of them ever broke.
I would say so...may even want to consider a manual tensioner. Are you replacing the timing belt? If so the tensioner is a smart plan.
Are there any cons to the manual tensioner? Other then keeping an eye on the tension over time and adjusting when necessary?
yeah, info i need now, and i don't have time to pay the 6 bux through paypal, and let PO have time to process it so i can read the damn thread sometime within the next week, i need it YESTERDAY!!!!
[Modified by satan_srv, 11:22 AM 10/22/2002]
Yeah I guess that's my question as well. Once you have the manual tensioner...when do you set the tension? on a cold engine? warm? How often do you adjust it after?
