94 hatch cx brake swap help!!
Old Feb 18, 2013 | 10:43 PM
jdmept's Avatar
Default 94 hatch cx brake swap help!!
Hey people i bought a cx hatch with rear disk conversion and i wanted to buy some drilled rotors i wanted to know if the rear rotors are biger than front ones.
All integra rear disk are bigger than cx civic right?? But same size as ex and si??
So the deal is that i want to swap the cx front suspesion to an ex so i can buy the drilled rotors as a set of 4 and have no problem installing.
What is the difference between the cx and ex/si front suspension
I know that ex use bigger rotors caliper and has abs
What do i do with abs are the brake lines longer or same size?does it bolt right up?
Any other info would be helpful
Plz just reply if u are going to help dont tell me to search im done searching not all problems are the same by sound the same but they are not
Old Feb 18, 2013 | 10:52 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: 94 hatch cx brake swap help!!
No one is going to spoon feed you!!! Try searching the suspension section!!! There is a sticky with all you need to know. Drilled rotors are worthless and dangerous unless your just going for looks. Keep to the blanks!!!
Old Feb 19, 2013 | 12:23 AM
jbpnoman's Avatar
The CX doesn't have rear discs, so you can't say they're smaller or bigger than any other car. They don't exist. If your car is rear disc swapped, good for you, it doesn't matter.
If you're trying to install front drilled rotors, you want to find rotors made for your chassis. It isn't that hard. Rotors also aren't sold in packs of four, so you shouldn't have to worry about that. Just buy rear rotors to match the donor car, and front rotors to match your chassis.
Old Feb 19, 2013 | 06:01 AM
JuggerNaut-CTR's Avatar
CX's didnt come with rear disk...
Makes no sense at all
Ummm...everything is bigger......
Not all ex's came with abs
Lines are the same
FYI....All 88-00 civic's and 90-01 integras that came with rear disk ALL share the same size rear rotor.......
Old Feb 19, 2013 | 06:06 AM
Y'all are too nice. I got answered out after the first 100 threads this week concerning brake upgrades.
Old Feb 19, 2013 | 07:12 AM
24TEN's Avatar
PHANTOM MENACE
^LOL at least no one is calling you names
Old Feb 19, 2013 | 08:07 AM
HUH??? Why would I be called names for telling him to search? Wouldn't bother me if they did, my wife calls me a ******* everyday! lol
Old Feb 19, 2013 | 08:11 AM
I was confused by that too. Maybe he thinks you are the op?
It was a little too nice lol. For some odd reason this spoon flew into my hand and took over.
Old Feb 19, 2013 | 08:18 AM
Actually I think he is talking to the Op for telling people to not tell him to search because he doesnt want to. So yeah he is lucky he has not been flamed for being too lazy!
EKkeen
10
Aug 28, 2012 05:49 AM
dE.fUsEd
Jun 20, 2011 03:22 PM
TylerB
Jan 5, 2008 08:52 PM
t57b18
Dec 4, 2005 07:14 AM
ROOROWNS
Mar 20, 2005 08:49 PM
