Gsr won't go in gear
98 Ek with a Gsr I was noticing it would not go in gear. Roads were realy snowy and I think it's packing in the clutch. I noticed it went in all gears with the car off.
The pedal grabs as soon as u lift it off the floor and when the snow gets in its like it won't engage.
Anyone ever have this? Can I make the pedal grab midway rather than off the floor?
The clutch is sealed so no chance of snow getting in.
It sounds like your clutch takup point is set too close to the firewall. You can adjust this out by turning a bolt on the top of the clutch pedal, near where it joins the master cylinder.
B is what you need to adjust:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/adjusting-clutch-pedal-catch-point-3057385/
johnqt3
Oct 7, 2005 11:05 AM
