ring gaps too big out of the box
I've had this problem in the past, that the end gaps on file fit rings are too big before any filing is done. Is there a company that makes rings pretty tight pre filing so that smaller gaps can be achieved? Or are you just ordering the next size up and filing them back down. This gets annoying especially when u are doing the work for other people and have to tell them the rings wont work
Is the p2w really loose? Of the two times I've used file to fit rings, they were from Arias and I had no problems with the engines running a 0.003" p2w. Just out of curiousity, how far off are you from where you really want to be?
I have had the same issue, even on all new parts that spec out. Even building my 700hp big block N/A car. It just happens some times, the machine shop i use just called and ordered a ring pack that was like 20 thous bigger, longer? I have been building motors for about 15 years, and yes it just happens, even with name brand guys.
i should add its happened more with hastings rings that come with off the shelf pistons as compared to when i order a ring set like the je pro seal rings
i think im just going to run the rings. i check the rest of them, they are all about .0175 top, and .022 second. imo worst case is it bleeds a tad bit of compression out, but the static on this engine is into the 12's so its not an issue. i dont expect it to have blowby issues
cyanid3
May 30, 2014 10:36 PM
