Problem with Weisco Piston rings!?
Old Apr 14, 2013 | 04:43 PM
arc_55's Avatar
Default Problem with Weisco Piston rings!?
I am wondering if anyone has come across this issue?
81.5mm wiesco pistons with a .0035" ptw clearance and checked after maching my cylinder walls are perfect with no out of round or taper.
When going to gap the top compression rings two right out of the box are pretty close at .018" while the other two are .024"! It varies big timer and i am not going to run .024" on the top ring with our power level in a street car.
I mixed the rings around and checked them in other bores and the gaps still remain the same.
I am wondering if anyone has come across this?
I have contacted who i purchased them from and hopefully we can work things out.
Old Apr 14, 2013 | 05:58 PM
Charlie Moua's Avatar
Default Re: Problem with Weisco Piston rings!?
I've seen some of the wiseco rings end up being a little looser out of the bag.
Not sure if wiseco has addressed this or not but they can send you new rings, you have to contact them directly.
Old Apr 14, 2013 | 06:11 PM
Muckman's Avatar
Moderator in Chief
Ive never had problems with the top rings before.
Its always the 2nd rings come loose out of the box.
You should be able to get 2 new sets no problem.
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
zenon8890
Feb 5, 2009 06:01 PM
torqueless
Mar 4, 2007 06:57 PM
rocket_R
Jun 13, 2006 11:09 PM
riceball777
Jan 17, 2004 09:41 PM
