94 ej1 no start. fuel, spark, timing good
Old Feb 15, 2013 | 09:20 AM
94ej1white's Avatar
Default 94 ej1 no start. fuel, spark, timing good
So i know the next question and that would be if I did a compression test, and yes I did. But Ill give you a little background. Does not leak or burn oil. No oil in coolant. Tested coil and control module in distributor and were fine. Pulled a wire and spark plug and verified spark. Can hear fuel pump working and smell gas when I crank. Sprayed starting fluid in the intake to check if fuel related. Pulled the timing belt thinking maybe it has slipped but its dead on.
150,60,150,90 were the numbers I got with engine cold. I agree thats not good but what can cause that to happen? I was driving it and stopped at a stop sign, went to take off and it just died. No other indication or cel. Im new to hondas but not to wrenching. Really stumped on this one and would like to know what you guys think, thanks! I have searched
Old Feb 15, 2013 | 09:22 AM
94ej1white's Avatar
Default Re: 94 ej1 no start. fuel, spark, timing good
1994 civic 2dr coupe d16z6 white with miss matched tires
Old Feb 15, 2013 | 10:51 AM
Former User's Avatar
You obviously have two dead cylinders. Do a cylinder leak down test to determine where compression is lost.
Old Feb 18, 2013 | 07:14 AM
94ej1white's Avatar
Turns out something in the distributor went bad. Although the control module and coil ohmed out fine. Runs like a champ now
Old Feb 18, 2013 | 08:10 AM
^Doesn't explain the compression test results. I assume that the compression test was done incorrectly.
Boost_em1_
Mar 17, 2014 01:04 PM
00siboy
17
Mar 15, 2011 11:06 AM
dashocker
Sep 1, 2008 03:26 PM
ericlee303
Apr 28, 2004 03:31 PM
FuzzyGreen
Jan 8, 2003 07:48 PM
