Question on MAP sensor
Old Oct 21, 2002 | 10:05 AM
Kataku2K3's Avatar
Default Question on MAP sensor
When you're motor is idling the is a vacuum on the MAP sensor, my question is as the throttle is opened up and the motor is reved up is more vacuum applied or less? Does the value in millibar go up or down? I know that as the motor is opened up that the signal voltage increases but i was just wondering which way the vac works. Thanks in advance.
Old Oct 21, 2002 | 10:30 AM
nolimits's Avatar
Default Re: Question on MAP sensor (JDMspecEG6)
Just reving the motor won't change the readings all that much. Putting the engine under a load increases manifold pressure while decreasing vacuum. When vacuum (negative figure) reaches 0 anything above that is boost (of course it would never get that far w/o FI.
Old Oct 21, 2002 | 02:11 PM
Kataku2K3's Avatar
Default Re: Question on MAP sensor (00turbosi)
Cool that's exactly what i needed. So idle has vac. Open throttle under load nears 0.
nuginu
K Series
Aug 17, 2013 11:26 AM
Raven2201
Jun 5, 2013 01:19 PM
chris3385
Jan 3, 2009 04:49 AM
maxspeedhonda
Nov 25, 2004 09:31 AM
builthatch
Mar 26, 2004 09:25 PM
