1992 acura Integra GS only gets 200km/full tank
Old Feb 13, 2013 | 02:21 PM
frossteedhehe's Avatar
Default 1992 acura Integra GS only gets 200km/full tank
Can anyone suggest some ideas as why my gas mileage is so LOW?? Like this is way to little even for a car with 250km on it. And also my gas light warnig doesn't come on either :/
Please give me some feedback, thank you
Old Feb 13, 2013 | 06:28 PM
broke_yo's Avatar
Default Re: 1992 acura Integra GS only gets 200km/full tank
that's low, when was you're last tune up? how do you drive?
bump so you can get some input.
Old Feb 14, 2013 | 03:44 AM
Not sure i bought the car about 2 weeks ago with 250 on it, should I change the spark plugs?
Old Feb 14, 2013 | 05:52 AM
fcm's Avatar
fcm
Old Fart
Do you even know when the last major tune up was done on the car?
If not, you need to do or have that done, then check your milage. 94
Old Feb 14, 2013 | 07:48 AM
I changed the oil just recently, I'm planning on changing the transmission oil also. What other "tune ups" would you recommend? Im also running on winter tires if that makes a difference
Old Feb 14, 2013 | 09:02 AM
fcm's Avatar
fcm
Old Fart
Timeing belt and tentioner, water pump, valve adjustment, cap, rotor, plugs, plug wires,
oil, filter, air filter, fuel filter. 94
Old Feb 14, 2013 | 09:47 AM
nicknack25's Avatar
If you know how to inspect the belts, see if they're are worn, if not then change all your belts, water pump, tensioner, spark plugs, spark plug wires, dizzy cap and rotor. Just a few things to do
Old Feb 14, 2013 | 10:19 AM
the belts look brand new, i don't see any cracks or wear on them whatsoever. but when i do start up the car i can hear the belts squealing of some sort not that loud but you can tell its the belt. would my fuel injectors also be an issue?
Old Feb 14, 2013 | 10:25 AM
JuggerNaut-CTR's Avatar
Altenator belt or ps belt is loose...just needs to be tightened. 5 min or less of work.
Do a standard tune-up and you should definetely see your mpg's go up.
kyled
Honda Civic (2006 - 2015)
16
Jan 17, 2013 07:08 AM
JDM215
Nov 30, 2010 03:51 AM
EvenStar
Dec 13, 2006 09:02 PM
JDM-EJ1
13
Apr 9, 2004 02:50 PM
BoostFrenzy.com
Apr 8, 2004 08:09 AM
