Coolant temp sensor wire cut!
Old Feb 13, 2013 | 09:12 AM
raider1qaz's Avatar
Default Coolant temp sensor wire cut!
Well i changed my head gasket on my 1996 honda civic last week and accidentally pulled to hard on the Coolant temp sensor that's under the distributor and wires got disconnected, and i cant just tape them together because the wires got yanked out of the plug.Any advice??
Old Feb 13, 2013 | 09:18 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Coolant temp sensor wire cut!
Search on here about re-pinning plugs and try to re-pin it.
Or, go to a junk yard, cut a plug off another 6th gen civic, and swap your de-pinned plug out. All it takes is a wire cutter, wire stripper, solder, flux, heat tape, and a soldering gun.
Old Feb 13, 2013 | 10:25 AM
HondaPartsHero's Avatar
Technical Hero
Is it the single wire sensor or the round two plug sensor?
Old Feb 13, 2013 | 11:19 AM
B_Swapped93's Avatar
going to a pick n pull is a lot easier than trying to re-pin and solder(trust me) i ripped my vss plug apart so i went to the yard and found one. then taped the wires toghter(after stripping them back 2 inches) workd fine to this day.
Old Feb 13, 2013 | 11:53 AM
raider1qaz's Avatar
my junk yard here all the civic they had the engines were all gone
Old Feb 13, 2013 | 11:57 AM
strategy400's Avatar
Same exact thing happened to me and I took the plug to my friendly neighborhood Honda dealership and the parts guy disassembled the plug at the counter, went in the back and came out with new pins for the plug (even gave me extras). No charge.
Took everything home and some wire strippers and a few crimps later my plug was like new again.
Old Feb 13, 2013 | 12:02 PM
Technical Hero
Old Feb 13, 2013 | 12:14 PM
The plug will stubbornly come apart if you pry at the rubber inside piece for a bit with a very small screwdriver. Something to do while you're watching TV.
Jeremy Harr
Feb 10, 2017 07:00 PM
carpenterkyle
Nov 3, 2012 07:45 PM
jwbnavy
Dec 4, 2007 02:20 PM
MOVE OVER
19
Dec 17, 2005 11:48 PM
SPORT INJECTION
Jun 27, 2003 10:48 AM
