Engine noises -vid-
Old Feb 12, 2013 | 01:29 PM
thejoker1993's Avatar
Default Engine noises -vid-
When my 97 accord vtec is warmed up the engine sounds like its knocking.
Listen closely
Old Feb 12, 2013 | 01:48 PM
Mishako129's Avatar
Default Re: Engine noises -vid-
That doesn't sound very good.
Old Feb 12, 2013 | 02:22 PM
It's been like this since I had the car and I put on 10k miles with it. No CEL or Anything
Old Feb 12, 2013 | 03:32 PM
Mishako129's Avatar
Someone on a DSM forum said to do this,
could be lifters. could be a bad harmonic balancer. Usually a rod knock will be the loudest when there is no load on the engine. If you quickly goose the throttle you will hear the knock whenever the rpm reaches its peak right before it falls off. It can be bad enough to knock all the time.
If you want to know for sure if its a bad rod bearing without dropping the pan you can do this.
Pull all the spark plugs.
Starting with cylinder number 1, rotate the engine to Top dead center on cyl number 1. Then rotate the crank enough for the piston to start the down stroke and stop. Using a long screwdriver push down firmly on the piston. If the bearing on the cylinder has play then the piston will drop down a little.
Do this for the other 3 cylinders.
Old Feb 12, 2013 | 04:35 PM
Well my car does makes the knocking when it's about to change to the next gear like in the high 2k range. However the engine still has power.
Old Feb 15, 2013 | 10:11 PM
bump!!!
Old Feb 16, 2013 | 01:04 PM
jdowen2's Avatar
Get a stethiscope and try and isolate area of concern. Could need a valve adjustment. You need to pull the valve cover and check.
Old Feb 16, 2013 | 04:41 PM
Peteypablo17's Avatar
After you're done doing that, make sure to stop by the local clinic for some hearing aids.
Old Feb 16, 2013 | 11:22 PM
The mechanic i went to said it probably wasn't the valves and that the noise is coming from the lower part of the engine (rods/bearings)
What can be the problem the noise happens when its about to shift in the 2k range. like 1 or 2 seconds before its shifts, you hear duh duh duh (noise in video) than it shifts. But if i put a greater load on it (pressing the gas pedal more firmly, the noise is less audible when its shifting in that range.
WilliamP
14
Oct 12, 2015 05:15 PM
fastlane2
Aug 22, 2009 01:36 PM
96Spec Ek
Dec 23, 2005 12:17 PM
555R
Dec 4, 2003 02:52 AM
Ideal R
Jul 27, 2001 06:55 AM
