Engine knock
Old Aug 22, 2009 | 10:47 AM
fastlane2's Avatar
Default Engine knock
My engine on my F22B2 accord has a upper knock around 2500rpms and vibrates around 3k to 3.25k rpms then revs fine. At first I thought its was a wrist pin going bad but it revs fine. Or thought it was a connecting rod. Upon future looking into it I think it might be a bad valve. The engine idles fine for now. It also starts fine in the morning and will climb a hill just fine. Any ideas? It started vibrating about 2 days ago.
Old Aug 22, 2009 | 01:06 PM
P_Adams's Avatar
Default Re: Engine knock
You could have an injector starting to play games. They can often make noise sometimes confused as a valve train noise (a light 'ticking'" noise). It could (conceivably) be causing a fuel delivery problem as well, thus the 'miss'.
Actually, the best way to work through this is to road test the vehicle and try duplicating the condition.
If I heard it, I'd probaly take almost no time figuring it out; but if you want to do it this way - you're going to have to be more precise in your description.
P
Old Aug 22, 2009 | 01:35 PM
fastlane2's Avatar
I'll make a recording of it and post it, if I can, It will take a few days. I also intend to do a compression test. Once the engine is warm it makes this noise all the time at the rev band described. If I power brake the engine no noise is present. It only makes it when I rev it at idle or when taking off slowly. I drove it up a hill to see it load made it show it self. But at 3k the motor vibrates. So I either go 65 or 80. It hates 70.
Old Aug 22, 2009 | 01:36 PM
fastlane2's Avatar
I'm going to check the resistance of the injectors.
landos2k
Honda S2000
Aug 14, 2015 12:42 PM
thejoker1993
Feb 16, 2013 11:22 PM
curtie94
Dec 28, 2011 05:28 PM
96Spec Ek
Dec 23, 2005 12:17 PM
JasinC19
May 28, 2004 09:50 PM
