Help timing light what mark do i use?????
i just replaced my distributor because its hella leaking, and the coil started to go bad. when i removed the dizzy i marked where the rotor was. it was at number one spark plug. when i installed the thing i put it on the same way it came off with the new dizzy.
motor a d15z1
So i jumped the ecu, checked the timing w/timing gun. i see the white line that is fartest to the firewall and three lines that is together facing front.
There are a total of four lines in all on the crank pulley.
what is the correct timing light to set the mark inline to????
i tried the white line fartest from the other three it seem to bottom out not to even come close to the mark.
what line do i use im confused?????
EG-SIXV-TECView Public ProfileSend a private message to EG-SIXV-TECFind More Posts by EG-SIXV-TECAdd EG-SIXV-TEC to Your Contacts
EG-SIXV-TEC
Feb 11, 2013 01:31 AM
91crx but i heard vtec
Nov 18, 2003 04:18 PM
