MrGasket MLS headgaskets.
Old Oct 21, 2002 | 07:59 AM
gtcali's Avatar
Default MrGasket MLS headgaskets.
Anybody using them?
I'll be using it for street/low boost appcation (under 10psi). Actually I ordered it already 'cause it was cheaper that an OEM one.
Old Oct 21, 2002 | 08:27 AM
b18bturbo's Avatar
Default Re: MrGasket MLS headgaskets. (gtcali)
junk... factory all the way.
Old Oct 21, 2002 | 08:35 AM
gtcali's Avatar
Default Re: MrGasket MLS headgaskets. (b18bturbo)
Damn. Gotcha.
OEM all the way.
Old Oct 21, 2002 | 09:00 AM
1.8T_EG's Avatar
oem or cometic??
Old Oct 21, 2002 | 10:20 AM
gtcali's Avatar
But of course summitracing said "Oh rats looks like the order already went out" I only ordered it a couple of hours ago.
Sigh...and I've been told an old friend of mine works at a local honda dealship.
1.8T_EG - I'd go oem for street/low boost use, cooper for fully built racing applications.
[Modified by gtcali, 11:23 AM 10/21/2002]
Old Oct 21, 2002 | 11:54 AM
gigantor's Avatar
Junk?
What makes you think Mr. Gasket head gaskets are junk?
Old Oct 21, 2002 | 11:59 AM
gtcali's Avatar
Default Re: MrGasket MLS headgaskets. (gigantor)
Ok- since it has been shipped. Why isn't it junk?
I'm thinking of returning it if I can get a good price on an OEM gasket from a friend.
Use it? Why?
Old Oct 22, 2002 | 12:40 PM
gigantor's Avatar
Use it? Why?
Mr. Gasket MLS head gaskets were designed as a high performance upgrade to the stock head gasket. The quality of materials is also much higher.
I've had one in my Integra for almost a year running 16psi.
Old May 30, 2005 | 08:13 PM
builthatch's Avatar
MiG-21 superfan
Back from the DEAD!!!!
anyone run a Mr. Gasket MLS setup?
Apexi seems to have stopped bringing the 1.5mm headgasket over...this seems like the next best thing...however i am not sure if it can accomodate anything more than a 75mm bore
I just want to know about experiences with these, Cometic is out of the question.
I think this is cool. I just don’t know who has used it…
It’s been out for a while, since like ’02, enough time for it to be deemed legit or not.
http://go.mrgasket.com/pdf/6225.pdf
a question that popped up for me is-
what are the 3 layers WITHOUT any spacers, thickness-wise? It tells you the spacer thicknesses, just not what the base layers are…from the compression ratio chart in the link, I figured out that the 3 layers by themselves is almost the thickness of a .037 honda gasket, about .035 I guess, since it has the 3 layer combo without spacers yielding a 9.2 CR on a stock z6…which is about right.…then you just add 1 or 2 spacers in any combination to that…pretty sick.
if I am correct, that means just the .5mm spacer would make the total thickness about 1.5mm, or 1.4478mm lol
Modified by builthatch at 12:48 AM 5/31/2005
Christopherian1982
Jan 22, 2009 05:38 PM
ProPerformance
Jun 16, 2007 08:25 AM
Toy Civic
Jan 24, 2007 02:04 PM
Takymoto
25
Oct 8, 2006 01:57 PM
D16A6Turbo
Dec 1, 2002 06:16 PM
