Passing Emissions
Old Feb 10, 2013 | 10:11 AM
Kannan08's Avatar
Icon3 Passing Emissions
Anyone know where I could pass my 95 civic hatch w d16z6 swap "under the table". It has a CEL, and I'm pretty sure the 3in exhust +can isnt going to help. Do they also run the VIN number?
Old Feb 10, 2013 | 11:37 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Passing Emissions
Lazy. Fix the CEL, clap on a stock exhaust system and stop trying to take shortcuts. Like you didn't know this was coming. Poor planning is a bitch.
Old Feb 10, 2013 | 11:47 PM
B(eighteen)C's Avatar
Exhaust size won't matter. Everything from the cat back to the intake must be stock or CARB approoved. What's the cel code for?
Old Feb 11, 2013 | 07:12 PM
hybridmiklo's Avatar
grumblemarc is on it.
Old Feb 20, 2013 | 06:32 PM
EricWS's Avatar
This is dependent on the state you are in...here you can't have a CEL on, or the 'puter throwing any codes (therein is a hint), and the emissions must be clean. It helps if everything appears stock. Or you can figure out how to get a P.O. box in a county that doesn't require "the test"!
Old Feb 20, 2013 | 11:48 PM
holmesnmanny's Avatar
fix the cel, don't worry about the exhaust and odds are a regular smog tech won't even notice the swap tbh
Old Feb 21, 2013 | 12:00 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
no
rukawa1one
Feb 11, 2005 09:15 PM
Shorty C
Aug 31, 2004 11:31 AM
jkn1515
Aug 26, 2003 12:23 PM
