Honda Transmission Fluid
Old Feb 9, 2013 | 08:17 AM
deLs0L93's Avatar
Default Honda Transmission Fluid
basically i want to change my Honda transmission fluid, i went to AutoZone and i told the guy i need a transmission fluid for a 93 stick shift Honda, and he give me this: http://www.castrol.com/castrol/secti...tentId=7028224
But it says automatic transmission, so i don't know if i can put this on my car,
I drive a 93 Honda Del Sol 1.6L Manual transmission
Old Feb 9, 2013 | 08:23 AM
belairbrian's Avatar
Default Re: Honda Transmission Fluid
No don't use it.
Quote from the 93 del sol owners manual page 111:
5 Speed manual Transmission
Only use an API Service SF or SG grade motor oil with a viscosity of SAE 10W-30 or 10W-40.
Old Feb 9, 2013 | 08:25 AM
zhunterzz's Avatar
Go to your local Honda dealer and ask the parts desk for transmission fluid. You'll be happy you did.
Old Feb 9, 2013 | 08:40 AM
Emeraldbomber's Avatar
Use 10w-30 motor oil. Honda prefers that in d series trannys because of the isb and other bearings.
Old Feb 9, 2013 | 08:55 AM
deLs0L93's Avatar
Originally Posted by belairbrian
No don't use it.
this should be fine?
http://shop.advanceautoparts.com/web...trol_8020477-p
Old Feb 9, 2013 | 09:12 AM
Originally Posted by deLs0L93
yep
Old Feb 9, 2013 | 10:12 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I was always under the impression using 10w-30 should only be temporary. Hondas prefer the factory honda mtf. Amsoil would probably the only other fluid I would personally use besides factory. It is not that expensive and it is in stock
Old Feb 9, 2013 | 10:29 AM
94EG8's Avatar
Seagull Management
10W30 is the right stuff for a '92 - '95 transmission. Honda MTF is just too thin and watery. It kills ISBs.
The '96 - '00 transmissions are a little different story. I didn't have good luck running 10W30 in them, notchy shifting. MTF works great, however it's still pretty hard on the input shaft bearing. I have no idea why they seemed to shift so much worse with 10W30 either, most of the parts are identical to the older transmissions.
Old Feb 12, 2013 | 03:03 PM
deLs0L93's Avatar
aight thanks everyone!!
Old Feb 12, 2013 | 06:24 PM
dazebreak's Avatar
Damn, really? I screwed up then...
Didn't honda say to use the Honda MTF in ALL M/T cars now (in some recommended fluid bulletin or something)?
Old Feb 12, 2013 | 06:39 PM
94EG8's Avatar
Seagull Management
Yep.
Probably, but that doesn't change the fact that it kills ISBs in those trannys. They would never said cheap 10W30 was better than their own MTF.
Old Feb 12, 2013 | 07:13 PM
dazebreak's Avatar
Yep.
LOL, true! I just replaced the ISB. Is it ok to drain, then add oil and have them mix? Also, isn't the ISB going out on the EG common no matter what?
Old Feb 12, 2013 | 07:26 PM
94EG8's Avatar
Seagull Management
Yes, that's fine.
Yes, but MTF certainly accelerates the process. Even though those transmissions are older I still see fewer ISB failures in previously unopened transmissions vs '96 - '00 transmissions. It's the same ISB so all you can really blame is the fluid. It's worth mentioning that the new bearings generally have a metal cage (I haven't seen a plastic cage in a while) but I still think they'll go bad.
Old Feb 12, 2013 | 07:31 PM
jbpnoman's Avatar
94, FWIW, my 98 DX had a plastic cage. When I replaced it, the new bearing had a metal cage. Oddly enough, the cage wasn't the problem - the outer race had cracked in multiple places. It came out in pieces. I think I've posted pictures of it before.
Old Feb 12, 2013 | 07:37 PM
94EG8's Avatar
Seagull Management
I've never seen the outer race crack, but I've seen lots of those ISBs get quite noisy and the plastic cage was still intact, the bearing gets rough and starts hammering and it breaks the cage, not the other way around. also, I've seen the top countershaft bearing, which has a metal cage, destroy itself, including shredding the metal cage.
Old Feb 12, 2013 | 07:42 PM
jbpnoman's Avatar
Yep, none of it surprises me in the transmission. That thing sees more abuse than the rest o the car combined, and it's also generally the least maintained part of anyone's car.
Old Feb 12, 2013 | 08:22 PM
TiNuts's Avatar
The parts guy at my local Honda dealer told me to run a 1/2 qt of Honda mtf and the rest royal purple 10w30. Something about the additives in the royal purple blah blah blah.
It feels notchier than what was in there before. It smelled like gear oil so I'm assuming mtf.
Old Feb 12, 2013 | 08:34 PM
dazebreak's Avatar
I did notice that when I changed it. I was hoping it was an improvement. A parts search reveals they used this bearing on the 2000-2006 insight also.
How's the shifting feel with the 10w40, about the same?
Old Feb 13, 2013 | 03:46 AM
94EG8's Avatar
Seagull Management
Every single person I know that tried Royal Purple in Honda transmission had horrible luck. It was either notchy or it would grind.
The cage has a better chance of staying together now, so you may not have to worry so much about getting every little piece of plastic cage out of the transmission anymore when change an ISB (those little pieces of plastic get lodged in the mainshaft oiling holes and other bearings get starved for oil and burn. That's why it's so important to completely disassemble the transmission and clean everything properly.
Run 10W30. In an S20 trans it should shift more or less the same as long as the transmission is in good shape. MTF probably shifts a slightly nicer but it shouldn't be a huge difference. Some guys really like Amsoil.
Old Feb 13, 2013 | 06:11 AM
MadVladCivic's Avatar
Bernardi Honda in Natick, MASS: www.bernardiparts.com
They ship fluids. Buy genuine Honda ATF, MTF etc far more
cheaply than you can get it locally (unless you are in Natick).
Old Feb 13, 2013 | 06:56 PM
Red_Army's Avatar
i could be unlazy and go look but does this apply to B series trannys too?
techsynthesis
Feb 3, 2008 05:18 AM
drummr6
Nov 4, 2005 11:46 AM
Red Ride
15
Apr 16, 2005 09:00 AM
James
Aug 6, 2003 07:23 AM
ooostenb
Feb 26, 2002 02:02 PM
